- Vie, 02 Dic 2005 15:31
#146850
hola estoy mirando motores y he visto este, que os parece?
Specifications:
RC Smart X-SPEED Brushless Motor 2900
>Rpm(Kv): 2900Rpm/V
>Resistance: 0.20
>Max Amps: 7
>Weight: 42g
>Length: 29mm
>Diameter:20mm
>Shaft Diameter: 2.0mm
>Recommended Battery: 7.2, 8.4, 11.1 Volt Li-Polymer Battery
Specifications:
>Rpm(Kv): 2900Rpm/V
>Resistance: 0.20
>Max Amps: 7
>Weight: 42g
>Length: 29mm
>Diameter:20mm
