este es del cy model de 75 amp,haber si te vale...
75A: 2-6LIPO/6-20NIMH
Phrases 1 Enter programming Mode
1. Connect your motor and receiver to the speed controller, but do not connect the battery yet.
2. Turn on your transmitter and move the throttle stick to the full throttle position (full up). Please Note: Most Futaba transmitters have the throttle channel reversed by default.
3. Connect your battery and the controller will initialize with a musical tone.
Phrases 2 Programming
After 3 seconds, the controller will start beeping a sequence of tones – a musical tone followed by one or more beeps. Each sequence represents a parameter that you can program and is repeated 3 times. The parameters are:
♪— Music Tone + 1 Beep Options 1. Cell Type and No. of Cells
♪— — Music Tone + 2 Beeps Options 2. Throttle Setting
♪— — — Music Tone + 3 Beeps Options 3. Brake Setting /Throttle type (for Heli)
♪— — — — Music Tone + 4 Beeps Options 4. Direction and Cutoff Type
♪— — — — — Music Tone + 5 Beeps Options 5. Timing Mode
Step 1. Starting, Enter Sub-optins. When you hear the sequence for the parameter you wish to program, move the throttle stick to the Center Position to Enter Sub-options.
The controller will then start beeping a Morse code sequence of short and long beeps representing the possible options you may choose for the selected parameter. See table 2 for a list of all programmable options. Each option sequence is repeated 3 times.
Step 2. Select and save, the select the option, move the throttle stick back to the Full-up-position., When you hear the sequence for the option you wish to select. The controller will then save the selected option, and sound a long beep as a confirmation. It then goes back to the beginning of the programming sequence (phrases 2).
Step 3. Complete programming and save options. Setup all the parameters you need to change. When complete, move the throttle stick to the Lowest (Down) Position. The controller will save all options and re-initialize in normal running mode so you can start your motor.
The table below summarizes the various programming options for each parameter:
* is Default Setting
1.♪— For (2S-7S)-ESC
Cell Type and Number of Cells
• — 1 Short + 1 Long NiMh/NiCD Auto Cell Count - 0.8V/Cell Cutoff Voltage
• — — 1 Short + 2 Long 7S Li-Po (25.9V) – 21V Cutoff Voltage
• — — — 1 Short + 3 Long 6S Li-Po (22.2V) –18V Cutoff Voltage
• — — — — 1 Short + 4 Long 5S Li-Po (18.5V) – 15V Cutoff Voltage
• — — — — —1 Short + 5 Long 4S Li-Po (14.8V) – 12V Cutoff Voltage
• — — — — — — 1 Short + 6 Long 3S Li-Po (11.1V) – 9V Cutoff Voltage
• — — — — — — — 1 Short + 7 Long 2S Li-Po (7.4V) – 8V Cutoff Voltage
2. Throttle Setting ♪— —
•• — 2 Short + 1 Long Auto Throttle Range *
•• — — 2 Short + 2 Long 1.1ms to 1.8ms
•• — — — 2 Short + 3 Long Hard start*
•• — — — — 2 Short + 4 Long Soft start
3. Brake Setting ( For normal Aircraft)
••• — 3 Short + 1 Long No Brake
••• — — 3 Short + 2 Long Soft Brake*
••• — — — 3 Short + 3 Long Medium Brake
••• — — — — 3 Short + 4 Long Hard Brake
•••• — 4 Short + 1 Long Clockwise Rotation *
•••• — — 4 Short + 2 Long Counterclockwise Rotation
•••• — — — 4 Short + 3 Long Soft Cutoff
•••• — — — — 4 Short + 4 Long Hard Cutoff *
5. Timing Mode Setting
••••• — 5 Short + 1 Long 1º - For 2-4 Pole Inrunner Motors *
••••• — — 5 Short + 2 Long 7º - For 6-8 Pole Motors
••••• — — — 5 Short + 3 Long 15º- For 10-14 Pole Outrunner Motors
••••• — — — — 5 Short + 4 Long 30º - For 10-14 Pole High-RPM Outrunner Motors
6. Pulse Width Modulation (PWM) Setting
•••••• — 6 Short + 1 Long 8KHz – For low RPM and low pole count motors *
•••••• — — 6 Short + 2 Long 16KHz – For most out runner motors
Molinero es que anda con molinillos...
