Por Jose Luis28
#672360
Hola, :lol: , a mi pregunta si es corriente continua pulsatoria, o alterna , variador-motor brushless, respuesta:
Hello,
current from 3phase controller to motor is specially modified DC current to AC values. So it is like AC.
Best regards
Jan
MODEL MOTORS s.r.o.
Okruzni 1144
Hradec Kralove 500 03
Czech Republic
He preguntado mas, espero.
El que dude, que me mande un privado con su e-mail y le reenvio los correos.
Sldts
Por ron_van_sommeren
#672664
Drawing of a very simple manual three phase-system. Controllers do the same only a little bit faster. Transistors/FETs do the switching, microprocessor does the thinking. This will give you some idea.
#672674
'Our' model motors don't use a sinusoidal signal but an approximation of a sinus, a trapezoid signal. At partial load, the trapezoid shaped voltage is PWM modulated ("one of these days I'm going to cut you into little pieces"). Voltage is chopped/spikey but current is not, motor induction smoothes the motorcurrent spikes.
Pictures of signals in/from an ESC
http://www.aerodesign.de/peter/2001/LRK ... o_eng.html
http://www.aerodesign.de/peter/2001/LRK ... ker1591256
Lessons In Electric Circuits -- Volume II (AC) - Chapter 13
-> Brushless DC motor
G2 Consulting - Motor Design and Power Electronics (course)
-> CHAPTER 9: ELECTRONIC CONTROLLERS
