- Vie, 10 Abr 2015 13:30
#1312427
He estado mirando esta camarita y la verdad es que tiene una pinta excelente .
Es una SJCAM (original) M10 WIFI (la SJ4000 en versión reducida y mas ligera)
La camara vale 108,26$ USD pero si hacemos un grupo de compra nos darán un codigo de descuento exclusivo, los que esteis interesados en unirse al grupo de compra dejad un mensaje abajo y os iré informando.
Viene con todo tipo de adaptadores para sujetarla a distintas superficies, FULL HD, 1080p, wifi, carcasa protectora sumergible 30 metros, apta para tarjetas de 32Gb.... GoPro tiembla.
Specifications
General
Brand: SJCAM
Model: M10
Type : Sport Carmera
Chipset Name: Novatek
Chipset : Novatek 96650
Special Function: Microphone, HDMI output
Storage
Max External Card Supported: SD 32G (not included)
Class Rating Requirements: Class 4 or Above
Display
Screen Size: 1.5inch
Screen Type: LCD
Power
Battery type: Removable
Capacity : 900mAh
Charge Way : USB charge by PC
Working time: 1080P about 90 minutes
Wide Angle: 170 degree wide angle
Video/Image/Audio
Decode Format: H.264
Video Format: MOV
Video Resolution : 1080P (1920 x 1080), 720P (1280 x 720)
Video System: PAL, NTSC
Video Frame Rate: 30fps, 60fps
Video Output: HDMI
Image Format : JPG
Image Resolution : 5M (2592 x 1944), 12M (4032 x 3024), 10M (3648 x 2736), 8M (3264 x 2448)
Audio System: Built-in microphone/speacker (AAC)
Functions
HDMI Output: Yes
Interface Type: HDMI, USB 2.0
Language: Simplified Chinese, Portuguese, Spanish, Traditional Chinese, French, Korean, English, Japanese, Russian, Italian, German
Dimension/Weight
Product Weight: 0.095 kg
Package Weight: 0.630 kg
Product Size (L x W x H): 5.5 x 4.5 x 5 cm / 2.1 x 1.7 x 1.9 inches
Package Size (L x W x H): 18 x 22 x 9 cm
Package Contents
Package Contents: 1 x M10 Action Camera, 2 x Double-side tap, 2 x Base, 2 x Band, 6 x Holder Accessories, 1 x Waterproof Case, 1 x USB Cable, 1 x Chinese / English User Manual
Specifications
General
Brand: SJCAM
Model: M10
Storage
Display
Screen Type: LCD
Power
Capacity : 900mAh
Video/Image/Audio
Video Format: MOV
Video Output: HDMI
Image Format : JPG
Functions
HDMI Output: Yes
Dimension/Weight
Package Contents
Házte a la idea ya.De ese avión no van a quedár ni las astíllas, para todo lo demás...
https://www.youtube.com/user/MsPoxas
