- Jue, 15 Dic 2011 16:36
#1102008
He visto en HobbyKing una emisora a muy buen precio (ahora no tienen stock, pero no tengo prisa). Quería que me dieseis vuestra opinión ya que pretendo iniciarme en esto del aeromodelismo y no sé mucho.
La emisora en cuestión es: HK-7X 2.4Ghz 7ch w/ 5 Model Memory TX & RX V2 (Mode 2) .
Las especificaciones (en inglés), son:
A reliable 7ch, 5 model 2.4Ghz transmitter system (version 2).
Hobby King HK-7X 2.4Ghz system is an pro level transmitter offering the reliability of 2.4Ghz spread spectrum technology and comes with a 8ch receiver. HK-7X can support all aircraft types, it features quick response, high precision
Features:
LED display, Show model type and battery voltage on normal status.
5 models parameters store supported
Support HELI(helicopter) mode and AERO mode. Following mode is supported in each mode.
Heli mode:
HP1 : Normal helicopter with 1 servo
HP2: Swash helicopter with 2 servos
HP3: CCPM 120 swash helicopter with 3 servos
AERO mode:
AP: Normal aero plane
VP : V-tail plane
DP: Del ta wing plane
7 channels standard servo signal output
Support 5 points throttle(THR) curve on NORMAL mode and IDLE mode.
Support 5 points pitch(PIT) curve on NORMAL mode, IDLE mode and HOLD mode.
Set reverse (REV), sub trim (SUB) and travel by LED and button.
Dual rate (DR) control supported
Throttlehold supported
Gyro sensitivity adjust supported
Return to battery voltage display after no operation till 30 seconds.
Beep when battery voltage low than 8.6V (Once per second).
Included;
1 x 2.4Ghz transmitter
1 x 2.4Ghz Receiver
1 x Bind Plug
1x Manual
Note:
Only HK-8X receiver is comptible with HK-7X transmitter.
Only HK-8R receiver is compatible with the HK-6X transmitter.
Only HK-8Xv2 receiver is compatible with the HK-7Xv2 transmitter.
¿Qué opinais (el precio no llega a 40 € puesta en casa)?
Features:
Heli mode:
AERO mode:
VP : V-tail plane
Included;
1 x 2.4Ghz Receiver
1 x Bind Plug
1x Manual
Note:
