Bueno..... vaya discusion mas tonta.
Esta claro que la capacidad de transmitir datos en 2,4ghz es mayor que en 35mhz, pero eso no quiere decir que 35mhz no sean suficientes.
En runryder postearon la siguiente tabla, espero que no moleste el corta y pega a su autor.
PCM and eCCPM
Transmitter |Receiver|MLF|MLL|MaxLF|MaxLL|Avg
ATX Stylus |92186Z |13 | 16| 27 | 30 | 21.5
Futaba 12Z |R5014DPS|14 | 14| 31.5| 31.5| 22.75 *
Futaba 14MZ |R5014DPS|14 | 14| 31.5| 31.5| 22.75 *
Futaba 14MZ |R5014DPS|14 | 24| 31.5| 41.5| 27.75 **
Futaba 14MZ |PCM1024 |29 | 93| 42 |106 | 67.5 ***
Futaba 9C |R149DP |44 |110| 57 |123 | 83.5
Futaba 9ZWC2 |R149DP |29 | 93| 41.9|105.9| 67.5
Hitec Eclipse7|QPCM |41 | 43| 62 | 64 | 52.5
JR 8103 |649S |27 | 59| 47 | 59 | 48
JR 9303 |649S |15 | 47| 36 | 47 | 36.3
JR 10X |649S |34 | 66| 54 | 66 | 55
Spektrum DX6 |AR6000 |59 | 63| 80.6| 88.6| 72.8
Spektrum DX7 |AR7000 |14 | 16| 36 | 40 | 26.5
Spektrum DX7 |AR6000 |31 | 35| 53 | 61 | 45
PPM and eCCPM
ATX Stylus |FM |13 | 17| 37 | 45 | 28
Futaba 9C |FM |50 | 55| 72.3| 82.3| 64.9
Hitec Eclipse7|FM |22 | 28| 42.6| 50.5| 35.8
JR 8103 |FM |10 | 14| 32 | 40 | 24
JR 10X |FM |10 | 14| 32 | 40 | 24
PCM and Normal (Channel 6)
ATX Stylus |92186Z |13 | 13| 27 | 27 | 20
JR 8103 |649S |38 | 58| 58 | 58 | 53
JR 10X |649S |35 | 55| 55 | 55 | 50
PPM and Normal (Channel 6)
Futaba 9C |FM |32 | 32| 59.3| 59.3| 45.65
JR 8103 |FM |16 | 16| 38 | 38 | 27
JR 10X |FM | 8 | 8| 30 | 30 | 19
All times are in milliseconds.
MLF - Minimum latency to first change at receivers output
MLL - Minimum latency to last change at receivers output
MaxLF - Maximum latency to first change at receivers output
MaxLL - Maximum latency to last change at receivers output
Avg - Average of MLF, MLL, MaxLF, and MaxLL
* Using channels 4, 5, and 6
** Using channels 1, 2, and 6
*** Deduced numbers from observed behavior
Todo el contenido del post esta en este link:
http://www.runryder.com/helicopter/t172571p1/
Deduciendo de la tabla, podemos ver como la stylus, Futabas 12z y 14z (con su receptor 3G) y la DX7 estan en unos tiempos de retraso mas o menos equivalentes, y las tres primeras son de 72Mhz. La Stylus es una emisora antigua (creo) y no tiene nada que envidiar a las otras. Las diferencias de precio (y de prestaciones) entre emisoras tambien son destacables, pero para la discusion que nos ocupa (el retraso en la recepcion) esta tabla es esclarecedora al maximo. Desde aqui muchas gracias a su autor.
Los fabricantes lo que tienen que hacer es espabilar, como ha hecho spektrum y ofrecer tecnologia de hoy a un precio razonable. Futaba lo unico que ha hecho estos años ha sido vivir del cuento con "remakes" de sus mismas emisoras una y otra vez, y cuando saca la 12z y la 14z.... pues menudo precio (un poco desfasado). Pero ahi esta el mercado para poner a todo el mundo en su sitio.
