- Jue, 24 Feb 2011 20:19
#1028358
Hola,buscando buscando,he encontrado esta tabla de conversion de pulgadas a milimetros,valido tambien para planchas de balsa y listones.creo que puede ser de mucha utilidad,para mi lo ha sido,espero os sirva
METRIC CONVERSION
1" = 25.4mm (conversion factor)
1/64" = .4mm
1/32" = .8mm
1/16" = 1.6mm
3/32" = 2.4mm
1/8" = 3.2mm
5/32" = 4mm
3/16" = 4.8mm
1/4" = 6.4mm
3/8" = 9.5mm
1/2" = 12.7mm
5/8" = 15.9mm
3/4" = 19mm
1" = 25.4mm
2" = 50.8mm
3" = 76.2mm
6" = 152.4mm
12" = 304.8mm
15" = 381mm
18" = 457.2mm
21" = 533.4mm
24" = 609.6mm
30" = 762mm
36" = 914.4mm
INCH-TO-MILLIMETER WOOD
Sheet Size Sheet Size
in inches in millimeters
1/64" x 2" x 24" = .4mm x 50.8mm x 609.6mm
3/32" x 3" x 18" = 2.4mm x 76.2mm x 457.2mm
3/32" x 3" x 24" = 2.4mm x 76.2mm x 609.6mm
3/32" x 3" x 30" = 2.4mm x 76.2mm x 762.0mm
3/32" x 3" x 36" = 2.4mm x 76.2mm x 914.4mm
1/8" x 3" x 24" = 3.2mm x 76.2mm x 609.6mm
1/8" x 3" x 30" = 3.2mm x 76.2mm x 762.0mm
1/8" x 3" x 36" = 3.2mm x 76.2mm x 914.4mm
1/4" x 1" x 24" = 6.4mm x 25.4mm x 609.6mm
Stick Size Stick Size
1/8" x 1/4" x 36" = 3.2mm x 6.4mm x 914.4mm
1/8" x 9/32" x 30" = 3.2mm x 7.1mm x 762.0mm
1/8" x 1/2" x 30" = 3.2mm x 12.7mm x 762.0mm
1/8" x 1" x 30" = 3.2mm x 25.4mm x 762.0mm
1/4" x 3/8" x 18" = 6.4mm x 9.5mm x 457.2mm
1/4" x 1/4" x 30" = 6.4mm x 6.4mm x 762.0mm
1/4" x 1/4" x 36" = 6.4mm x 6.4mm x 914.4mm
3/8" x 1/2" x 30" = 9.5mm x 12.7mm x 762.0mm
3/8" x 3/4" x 8" = 9.5mm x 19.0mm x 203.2mm
3/8" x 1-1/4" x 4" = 9.5mm x 31.8mm x 101.6mm
1/2" x 1/2" x 30" = 12.7mm x 12.7mm x 762.0mm
1/2" x 7/8" x 24" = 12.7mm x 22.2mm x 609.6mm
METRIC CONVERSION
1/64" = .4mm
1/32" = .8mm
1/16" = 1.6mm
3/32" = 2.4mm
1/8" = 3.2mm
5/32" = 4mm
3/16" = 4.8mm
1/4" = 6.4mm
3/8" = 9.5mm
1/2" = 12.7mm
5/8" = 15.9mm
3/4" = 19mm
1" = 25.4mm
2" = 50.8mm
3" = 76.2mm
6" = 152.4mm
12" = 304.8mm
15" = 381mm
18" = 457.2mm
21" = 533.4mm
24" = 609.6mm
30" = 762mm
36" = 914.4mm
