- Lun, 28 Dic 2009 13:46
#901052
Wenas!!
Me he comprado el Tarot 500, por 510 dolares. Con motor Scorpion, Brushless Scorpion 75A, helices, 3x DS510, Gyro GP750 con DS520 y bateria V-Plus XP 2600mAh 6S1P 30C-50C
Que os parece?
Specification:
●Length:850mm
●Height:310mm
●Main Blade Length:425mm
●Main Rotor Diameter:970mm
●Tail Rotor Diameter:200mm
●Motor Ponion Gear:12T/13T
●Main Drive Gear:162T
●Autorotation Tail Drive Gear:145T
●Tail Drive Gear:31T
●Drive Gear Ratio:1:13.5:4.68/1:12.46:4.68
●Weight(w/o power system):935g
●Flying Weight:Approx 1700g
●Color carton:48.3x18.7x9.8cm
●Outer carton:58x50x42cm ,12sets/ctn
●Features
1.Electric power system.
2.Simple and light weight design provides awesome flight performance and extreme 3D capability.
3.Beautiful factory painted fiberglass canopy.
4.Rotor head/tail with thrust bearings.
5.Direct-to-swash CCPM linkage.
6.Center of gravity of Battery tray designed close to the rotor head.
7.Tail rotor drive belt system.
8.Fully driven tail auto rotation system.
9.Tail servo boom mount.
Accessories:
1.)Tarot 500S Kit SetX1 set
2.)Fiberglass painted canopyX1
3.)430mm Fibre Glass 3D Blades YB X1
4.)ESC 75A Brushless ESCX1
(Built-in 5.5V step-less adjustable BEC6A 7A Max)
5.)Scorpion Brushless Motor HK3026 (V2) KV1900 X1
6.)GP750 Head Lock Gyro X1
7.)DS510 Digital Servo K10419A X3
8.)DS520 Digital Servo K10420A X1
9.)V-Plus XP 2600mAh 6S1P 30C-50C X1
10.)Motor ponion gear 13T X1
Que os parece?
Specification:
●Length:850mm
●Height:310mm
●Features
Accessories:
T-rex 500, scorpion HK-3026-1900kv, variador scorpion commander 90A, flybarless 3G
T-Rex 600 Nitro Limited Edition con flybarless 3G y os 55 hz
Spektrum Dx7
Spektrum Dx7
