Bueno, por si tienes dudas, ahí va otra opción de precio similar al tritón, pero con más prestaciones:
DuraTrax IntelliPeak ICE DC Competition Charger
Handles 1-10 NiCd or NiMH cells, and 1-4 lithium-ion (Li-Ion) or lithium-polymer (Li-Po) cells
Wide adjustable current ranges for fast charge (0.1-8.0A) and discharge (0.1-10.0A)
Four charge modes, linear, reflex, impulse and 4-step plus optional battery temperature monitoring
"Constant current/constant voltage" charge method for Li-Ion/Li-Po batteries
Reverse Polarity Protection
Peak detection with adjustable sensitivity for NiCd and NiMH batteries
0-500mA adjustable TRICKLE charge current for NiCd and NiMH
0.8-1.1V adjustable discharge cut-off voltage for NiCd and NiMH
2.5-3.7V adjustable discharge cut-off voltage for Li-Ion/Li-Po
Performs 1-10 cycles (NiCd and NiMH only)-retrieves data for 10 full cycles
Stores info for up to 10 batteries in memory by custom names for easy recall and charger set-up
LCD screen shows 8 lines of data and 21 characters per line
1.0-8.0V adjustable output, time adjustable from 1-120 minutes and 10A constant current (30A surge) for motor break-in
Also breaks-in electric motors and operates commutator lathes
http://www2.towerhobbies.com/cgi-bin/wt ... XHDJ1&P=ML
Un saludo y felices vuelos!!!
