- Mar, 18 Dic 2007 13:20
#593775
Despues de buscar por el foro,y encontrar poca informacion respecto a lo que busco,me gustaria que me dieras vuestra opinion respecto a dos gyros:
-el Telebee Head Lock
Product Features
Tuning gyro gain on board or by transmitter, auto calibrate, dual-rate and headlock mode included, ultra light design.
Reverse Switch available for easy setting.
New ATV Adjust Switch - allow you to adjust and fine tune the travels of the tail servo easily.
Small Size Piezoelectric Ceramic Gyro
voltage used: 4.2V to 7V
Power Consumption: APprox 33ma
Operation temp: -5° Cto +60°C
Built-in Drift Cancel - Circuit
Temperature Compensation Circuit
Input power: 5V-6V DC
Weight: 9g
Size: 19 x 19 x 13mm
-el GY400 Head Lock
Specification: Control System : Digital advanced PI (Proportional Integration) Control
Gyro sensor: SMM (Silicon Micro Machine) system vibration gyro
Operating voltage: +4 to +6VDC
Operating temperature range: -10 degree to +45 degree
Dimensions: 21.8 X 21.8 X 19.00mm
Weight: 15g (including connector)
Function: Gyro operation direction switch, DS mode switch, Control delay trimmer, Limit trimmer Remote gain control, AVCS/normal mode switching
Cual creeis que tiene mejores prestaciones?(sin tener en cuenta el precio)
Muchas gracias
1 saludo
Product Features
Weight: 9g
-el GY400 Head Lock
Muchas gracias
1 saludo
