- Lun, 26 Sep 2011 19:36
#1083700
Me hecho una lancha de tres puntas totalmente casera. Estoy pensando en comprar un motor y un variador. El peso del barco es 1,8Kg aprox.
Este motor estaria bien para un barco con ese peso
http://cgi.ebay.es/ws/eBayISAPI.dll?Vie ... 488wt_1068
Que tipo de helice deberia poner, si me pusierais link lo agradeceria, tengo que decir que la helice va totalmente sumergida.
Especificaciones del motor:
Specification
Specifications of Water Cool Brushless motor
Brushless motor Model SeaMonster-2845-3600Kv
Rotational Speed 3600Kv (rpm/v)
Max Current 45A
Power (W) 700W
Input Voltage 7.4v- 14.8v
Motor Weight 170g
Max. Efficiency 98%
No Load Current 1.5A
Internal Resistance 18mO
Motor Dimensions (Diameter x Length) 35mm x 58 mm + 10 mm ( pipe )
Shaft Dimensions (Diameter x Length) 4.0mm x 15mm
Input Battery Types NiCd/ Nimh/ Li-po Battery
Cooling Type Water Cool
Wire Winds 5
Recommend Model RC Model Boat
Feature of Water Cool Brushless motor
Water Cooling Brushless motor which have special design with water cooling system. This system uses water to cool off the motor which can make the motor more efficient and Powerful.
Specification of ESC
Size: 74 x 41 x 23 mm
Constant Current: 150A
Max Current: 160A
BEC output: 5A
Input Volt: 6 - 22.2V (2-6 LIPO / 4 - 20 NIMH)
Low-Voltage Cutoff: Auto detect and set
Advantage of Sky Wing Speed Controller
Low resistance
High rate PWM
Sixteen cellsMax
Low torquestart
Soft startramp up
Userprogrammable brake
Auto motorcutoff with reset
Throttlerange self-adjusting
Auto shutdown when signal is lost
Low voltage auto setting based on battery Safe power arming program ensures motor will not run accidentally after turn on
Package Content :
1 x SeaMonster Water Cool Brushless Motor 3600kv (700W) with accessories
1 x 150A Water-Cool Brushless Motor ESC
Specification
Max Current 45A
Power (W) 700W
Motor Weight 170g
Max. Efficiency 98%
Wire Winds 5
Max Current: 160A
BEC output: 5A
Low resistance
High rate PWM
Sixteen cellsMax
Low torquestart
Soft startramp up
Package Content :
