Por funfly
#594500
vendo este conjunto : variador 120A y programador usb con soft.
precio conjunto 80 euros con portes.
Speed Controller Features
High rate (10 KHz) switching (PWM)
3 to 6 Li-poly cells with receiver.
Dynamic braking ensures prompt prop folding.
BEC (2.0A) provides power to receiver and servos.
Over temperature protection.
User programmable Features.
Low-voltage protection - Programmable
Cutoff can be programmed for motor stop or reduced power.
Brake Type.
Throttle Range.
Timing Advance.
Safe “power on?arming program.
Low torque “soft start?prevents damage to fragile gearboxes.
Auto shut down in 4sec after signal is lost or radio interference becomes severe.
Microprocessor controlled.
Programmable rotation.
Specifics;
This BESC has an extremely smooth throttle curve and excellent programming features. it is oneof the best quality BESC coming from China right now.
Item comes with a 12 month warranty
Max Load : 130A
Max Voltage : 6 cell 25v
BEC 2A
programador :USB key used to program all PRO Series hexTronik Brushless Speed Controlers.
Sofware and manual available
Por emilio477
#594721
Mejor pon este post en compra-venta :wink:
Por emilio477
#594722
repetido :oops:
