- Jue, 06 Sep 2007 1:32
#531420
se puede utilizar este variador oara el trex 600?
estas son las instrucciones
First, connect the motor and receiver to the speed controller
Remove battery power from the speed controller.
Turn on the transmitter.
Move throttle stick on full power position (UP Position)
Reconnect battery power to the speed controller
After 3 sec you can hear (all sound is 3 times)
?— CELL Type AND Number
?— — BRAKE
?— — — TIMING MODE
?— — — — PWM
ON you need programming menu, move the throttle stick to the middle position
1. CELL Type and Number SET
•— NiMh/Nicd AUTO?0.8V/CELL*?
•— — 4LIPO ?2.75V/CELL?
•— — — 5LIPO?2.75V/CELL?
•— — — — 6LIPO?2.75V/CELL?
*IF used 2LIPO you can use the option (select the NiMh/Nicd AUTO)
2. BRAKE SET
••— NO
•••— — SOFT
•••— — — MID
•••— — — — HARD
3. TIMING MODE SET
•••— 3º
••••— — 8 º
•••••— — — 15º
•••••— — — — 30º
4?PWM SET
••••— 8KHZ
••••— — 16KHZ
••••— — — 32KHZ
IF the option is you need, then move the throttle stick to UP position.
The long BEEP is save the option. and the system will go to the programming menu.
You can setup other options.
When all you need option is setup ok, push the throttle stick to down position, after
1 sec the system will save all option, then you can start the motor now!!
Lo que no entiendo es lo de los grados esos que pone por ahi
?— — BRAKE
?— — — TIMING MODE
?— — — — PWM
2. BRAKE SET
••— NO
•••— — SOFT
•••— — — MID
•••— — — — HARD
3. TIMING MODE SET
•••— 3º
••••— — 8 º
•••••— — — 15º
•••••— — — — 30º
4?PWM SET
••••— 8KHZ
••••— — 16KHZ
••••— — — 32KHZ
