chus escribió:buenas,, se me ha roto hoy el variador de mi trex 600,el termoretractil de rozar entre si se ha pelado y ha juntado dos cables del motor, total achicharrado,me gustaria sabe3r que variador le meteriais y si puede ser cuanto puede costar.
gracias
Hola chus, yo la verdad o bien me pillaria el de 100A de Align o este que tienen en Hobbycity que desde luego he visto comentarios muy buenos de la peña que lo esta utilizando.
TURNIGY Plush 100amp Speed Controller
Turnigy 100A Brushless Speed Controller
This besc is mounted on a precision made PCB, it also has an oversized heatsink held light against the FETs with screws.
It looks to be and performs as a serious high amp BESC.
Cont Current: 100A
Burst Current: 105A
BEC Mode: Opto Only
Lipo Cells: 2-6
NiMH : 5-18
Weight: 125g
User Programmable, both via controller and optional programming card. The programming card is an excellent item as it instantly tells the user the current settings and with a few simple clicks of the buttons, the user can change the settings and have graphical reassurance of those changes.
The programming card is an excellent Item and simple to use!
https://www.hobbycity.com/hobbycity/sto ... oduct=3728
