- Mar, 03 Abr 2007 17:25
#443833
Quiero consejo. Cual de los dos seria mejor para un aun prinicipiante.
He manejado el Honey Bee CP2.
WALKERA
DRAGONFLY #36
DF36 standard 199 euros Regalo de taka taka y cable serie
DF36 PRO ( bateria de lipo, activador y motor brushless) 265 euros regalo de taka taka y cable serie
HELICOPTERO 3D CON ACTIVACION DEL ROTOR TRASERO POR BANDA
6 CANALES
GYRO HEADING HOLD(MUCHO MEJOR QUE EL ORIGINAL WALKERA)
SE LE PUEDEN ACTUALIZAR LOS SERVOS A TOWER PRO(MAS CALIDAD QUE WALKERA)
ROTOR PRINCIPAL 63 CMS
LARGO DEL HELICOPTERO 54 CMS
MOTOR PRINCIPAL 380 ACTUALIZABLE A BRUSHLESS 180 O 380
MAXIMA CAPACIDAD DE CARGA 580 GMS
ROTOR TRASERO ACTIVADO POR BANDA
TRANSMISOR Y RECEPTOR DE 6 CANALES
VOLTAGE 11.1V
MOVIMIENTOS DEL CONTROL:
ARRIBA, ABAJO, DERECHA, IZQUERDA, GIRO SOBRE SU PROPIO EJE EN AMBAS DIRECCIONES Y VUELO INVERTIDO, TOTALMENTE ACROBATICO
TOTALMENTE ENSAMBLADO
RTF (READY TO FLY) SOLO SACARLO DE LA CAJA, CARGAR LAS BATERIAS, PONERLE BATERIAS AL CONTROL Y A VOLAR
DF60B
Heli de 7 canales con cuerpo metalico y rotor principal de aluminio. Bateria de lipo
285 euros
o Pitch-axis
Roll-axis
Collective Pitch
Motor Speed
Others: Gear switch, 3D conversion, PIT adjustment, and exponential function
Specification:
o (1). Main Rotor Diameter: 620 mm
(2). Tail Rotor Diameter: 145 mm
(3). Overall Length: 600 mm
(4). Receiver: RX- PCM-701
(5). Drive System: 380 PH
(6). Battery: Ni-MH 12V 650mAh
(7). All-up Weight: 570?620g (Battery included)
(8). Transmitter: WK-PCM-0701
(9). Gyro: WK-G007
(10).LI-POLYMER Battery 2200mAh 11.1V 10C and charger
(11).Speed Controller: WTS-20A-02 Servo: weight 8.5g / speed 0.11sec/60°/ torque 0.9kg/cm / dimension 22.5X11.5X24mm
Features:
o (1). CCPM mixing control system and collective pitch structure make perfect 3D maneuvers such as roll, inverted, and swoop flights.
(2). The design of metal main frame, metal swash plate and metal rotor head is of legerity, innovation, precise and stability (except 59# and 60#). The autorotation landing system, made of high quality one-way bearing, maximally protects your helicopter from damage .
[/img][/list]
WALKERA
DRAGONFLY #36
6 CANALES
VOLTAGE 11.1V
DF60B
285 euros
o Pitch-axis
Roll-axis
Collective Pitch
Motor Speed
Specification:
(9). Gyro: WK-G007
Features:
[/img][/list]
