- Vie, 06 Jun 2008 16:27
#683493
me gustaria saber si esto me vale para un zoom 4d
Specifications:
-Rpm(Kv): 5000 Rpm/V
-Max Currect: 25A
-Max Eff: 96%
-Total Length: 40.1mm (Motor and Shaft)
-Motor Body Diameter: 27.8mm
-Shaft Diameter: 2.26mm(Front)
-Shaft Length: 13.9mm
-Recommended Input Voltage: 6 - 18 Volt
Specifications:
-Dimensions: 51mm x 24mm x 8.3mm (Approximately)
-Cable Length: 72mm (Battery) / 72mm (Motor)
-Cable Type: 16AWG (Battery and Motor)
-Cable Length: 190mm (For Receiver)
-Sustaining Input Voltage: 6 - 18v
-BEC Output Current: 3.0A
-Continuous Output Current: 30A
-Max Output Current: 40A
-Inside Impedance: 0.0044
-Low-Voltage, Cut Electricity Protection: Yes
Specifications:
-Max Currect: 25A
-Max Eff: 96%
Specifications:
